are stock Lt1 heads cast iron or aluminum?
Old Feb 15, 2004 | 03:40 PM
  #16
Originally posted by 96capricemgr
Caprice, Impala, Roadmaster are b-bodies
Fleetwood is indead a d-body, it has a longer wheelbase(7" in the wheels 13" overall) than the other hence the seperate designation.
I wonder how these guys are gonna handle the news?
Old Feb 15, 2004 | 03:49 PM
  #17
96capricemgr's Avatar
I am what you might call active on a couple Imapala forums. I drop in here to see what you guys are doing since we share a basic engine and transmission. Actually my car came with an L99 so I HAD a 7.625 axle like you guys too, but I chucked that after the LT1 swap. Don't you wish you could just throw a 8.5 from a LT1 b-body under your car .
Old Feb 15, 2004 | 04:07 PM
  #18
carlos64030's Avatar
I was wrong.
Old Feb 15, 2004 | 04:18 PM
  #19
badblackta's Avatar
Dont forget corvettes they are aluminum heads too.
Old Feb 15, 2004 | 04:38 PM
  #20
simple's Avatar
yes those are Y-body cars!
Y-body= Corvette (alum)
F-body= Camaro + Firebird (alum)
B-body= Caprice + Impala + Roadmaster (iron)
D-body= Fleetwood (still unconfirmed tho) ?? possible B-body (iron)
Steve
Old Feb 16, 2004 | 12:07 AM
  #21
JasonL's Avatar
Looks like the Fleetwood is indeed a D-body.
http://myweb.accessus.net/~090/cfb.html
Under Vehicle Specifications, Chassis:
GM Body Type: D-Body (Note that the D-cars are really a slightly stretched version of the B-car and are virtually identical except for the wheelbase.)
Old Feb 16, 2004 | 01:49 AM
  #22
Heatmaker's Avatar
Advanced Member
Fight! Fight! Fight! FIght! Fight!
Old Feb 16, 2004 | 09:23 AM
  #23
Yes, it appears so.
Old Feb 16, 2004 | 09:35 AM
  #24
shoebox, that site has been messed up for sometime a real shame it had some great info. The current goto for 94-96 b,d-body tech is http://www.impalassforum.com/
Old Feb 16, 2004 | 10:53 AM
  #25
LT1 Abuser's Avatar
Originally posted by NOMAD
-Shannon
say what ? ? ? ?
Old Feb 16, 2004 | 12:02 PM
  #26
SS Mark's Avatar
What the duece is a L99?
Old Feb 16, 2004 | 12:16 PM
  #27
LT1 Abuser's Avatar
The 265 cubic inch version of the LT1 found in some B-bodies
Old Feb 16, 2004 | 12:23 PM
  #28
A 265 cubic inch 4.3L LT1, smaller bore and stroke but all the external stuff is the same. Really it is it's own block, heads, crank, rods(5.940") and pistons, but the manifolds, wiring, opti, ater pump, tin and such are all the same. It was the base engine in the 94-96 Caprice only, most Chevy dealers will say the 4.3 was only ever a V6 but they would be wrong. When I had that thing I had a heck of a time getting the counter goon at the parts store to hand over 8 plugs instead of 6. It was a good little motor a bit torque challenged as one might expect but OK with 200hp 245 ft.lbs. I think it would have been perfect instead of the V6 in the base f-bodies, I could touch 30mpg if I drove sensibly. After I swapped it out I tore it apart and found crosshatch in all cylinders that was 110K.
Old Feb 16, 2004 | 06:05 PM
  #29
NOMAD's Avatar
Originally posted by LT1 Abuser
say what ? ? ? ?
I was mocking everyone else... yeah... thats it... Lol
-Shannon
HectorM52
Jul 30, 2017 11:46 AM
*Emilia*
May 13, 2015 09:05 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
Killer94z
Jan 13, 2015 12:06 PM
