stock lt1 heads?
Old Mar 19, 2005 | 12:18 PM
irishz28's Avatar
stock lt1 heads?
would i just be wasting my time, porting my stock heads. i want to use the comp cams 306 cam. should i just say screw it i start looking for a set of good after market heads?
Old Mar 19, 2005 | 12:24 PM
396D1SS's Avatar
Re: stock lt1 heads?
The ported stock heads will work fine, how much power do you wanna make? Unless you plan on going like mid 10's all motor they will work. people have made 410+rwhp with stock ported heads
Old Mar 19, 2005 | 12:25 PM
96capricemgr's Avatar
People are far too quick to ditch the stock heads, they are a great starting point especially if staying stock displacement or low rev stroker. Check out eportworks.com he is a board favorite porter with exellent prices.
Old Mar 31, 2005 | 11:03 AM
irishz28's Avatar
what kind of power do you guys think im looking at, with the stock ported heads and a 306 cam, ill have all the bolt ons by the time im ready to do this. also with this setup would i benefit any from changing my fuel pump, putting in a adjustable fuel pressure regulator, injectors, and a throttle body?
Old May 5, 2005 | 02:35 AM
irishz28's Avatar
do you guys think it would be worth it to put bigger valves in the stock heads?
Old May 5, 2005 | 06:52 PM
Skip the adjustable fuel pressure regulator all you would accomplish with it is making your tuners job harder.
The stock heads can benifit from larger valves if the bowl work is done to match, if self porting maybe skip it, if having them ported then talk to the porter.
Old May 6, 2005 | 02:18 AM
irishz28's Avatar
thanks man thats what i needed to hear. what size valves should i use if im using a cc 306 cam? im trying to get around 400 rwhp without taping into the block.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
Killer94z
Jan 13, 2015 12:06 PM
Brian-94TA
Jul 31, 2002 02:52 PM
