Finding a Short???
Old May 4, 2005 | 06:43 PM
Black_Z28's Avatar
Finding a Short???
I just scanned my car to find the following codes, 100 and 1657. The 100 code is-Mass Air Flow (MAF) insufficient signal activity, and the 1657 code is-Skip shift/One to four upshift system control circuit, which is probably why it need to push my shifter into reverse. Anyways, this must be a short somewhere, or a bad wire. Since both of these are not functioning, instead of just the MAF for example. Anyone know of a good way to track down a bad ground, or a short? I'd really like to get this fixed, because 15mpg isn't all that fun. Any ideas of help would be great.
Old May 6, 2005 | 05:13 AM
slopokrodrigez's Avatar
Re: Finding a Short???
You have checked the presence of 12 volts on the pink wire to both the MAF and Skip shift solenoid right? Both are powered by the 20AMP #10 fuse in the underhood fuse panel. But then so are the O2s and you didn't mention a problem with them.
Magenta_Hearts
Mar 5, 2015 07:01 AM
grgguy
17
Feb 23, 2015 07:57 PM
pimpss96
Feb 12, 2015 01:28 PM
11racing
Classic Engine Tech
Dec 26, 2014 05:40 PM
Decromin
Aug 18, 2002 10:11 AM
