Stock Lt1 Cam Change
Old Apr 6, 2006 | 06:29 PM
Executioner2k5's Avatar
I wanted to Find Out If I Could Change My Stock LT1 Cam With a Stock LT4 Cam With Out Having To Change Any Thing?
Old Apr 6, 2006 | 06:34 PM
MeanGreen97Z's Avatar
Re: Stock Lt1 Cam Change
The lt4 cam is smaller than the lt1 cam. Just add 1.6 rockers to your lt1 cam and add some 35$ lt4 valve springs and presto.... instant hp.
Old Apr 6, 2006 | 06:43 PM
I want to car the have that deep lobeing sound if i keep the same cam and change the springs and rockers will it give me that sound?
Old Apr 6, 2006 | 06:47 PM
TransAm396's Avatar
not at all...the cam is what changes it. and to tell you the truth the springs are probably the hardest part. Your best bet is to just get the LT4 hotcam kit..along with the "lope" youll get a very noticable increase in power.-Mark
Old Apr 6, 2006 | 06:51 PM
Ya the LT4 HOT cam will give you the lope. A regular LT4 cam is just a peanut cam. The kit includes the rockers, springs and hardware, and the cam. Not bad for around 500$.
Old Apr 6, 2006 | 06:59 PM
I was thinking about gettin the Hot Cam but i want to change as little as possible right now cause i am tight on money.
Old Apr 6, 2006 | 07:18 PM
Then do some 1.6 roller rockers. I'll break it down for you...
Profrom NSA 1.6 RRs - 170$
LT4 valve springs - 35$
GMPP guideplates - 18$
Comp Cams hardened pushrods - 35$
New valve cover gaskets - 12$
Valve seals - 30$
That cheap enough for you? Id say depending on how bad your current valve springs are you can see 15rwhp.
Old Apr 8, 2006 | 11:37 AM
Compstall's Avatar
I saw 7 at the wheels with just the spring/rocker swap.
oldschool
Feb 9, 2016 09:21 PM
birdblack
Dec 30, 2014 06:59 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
