stock heads ported
Old Mar 11, 2007 | 03:17 PM
BowtieCamaro6's Avatar
stock heads ported
just wondering if lt1 heads would be worth porting and for the money cause i really like the le1 and le2 packages. but kinda out of my price range cause im still in school. So i was just wondering if porting the heads would be worth it?
Old Mar 11, 2007 | 03:19 PM
Z95m6's Avatar
Are you talking about porting the heads yourself? If so I'd say no don't do it. The LE packages start out with stock LT1 head castings.
Are you asking if you could do it yourself, or if you should go look for someone who charges less than ePortworks to port LT1 heads? Obvisouly porting stock LT1 heads can make huge power, but you need someone with a proven track record to do it.
Old Mar 11, 2007 | 03:40 PM
i think ill end up porting the heads myself tell i can save up money to buy a set. I really think i could port a set myself. I just dont want to port and it make less power if thats possible. I just dont know how much i can port out and stuff. But what i was talking about is i was thinking about finding a local place around here that ports heads and see how much it cost if its worth the price i might do that.
Old Mar 11, 2007 | 03:44 PM
Z95m6's Avatar
Lloyd's LE1 heads are pretty dirt cheap and it'll be tough to find someone that knows what they're doing for less money.
Old Mar 11, 2007 | 06:46 PM
2000GTP's Avatar
Lloyd sells the LE1 heads and also a budget head for a decent price and his work is well known and documented. You might not get the same if you go to some local shop.
Old Mar 11, 2007 | 07:04 PM
alright think yall for the help. Im just tired of these turbo four bangers and mustangs and i would like to make a pull on some ls1s but thats a long way away
Old Mar 12, 2007 | 10:57 AM
has anybody on here ever ported there own lt1 heads??
Old Mar 12, 2007 | 11:12 AM
arcticz28the383's Avatar
I started to port my own stock heads which arent on the car right now and it is a tough long job with hand tools. You need to buy some expensive aluminum cutting bits with the correct air or electric dremel tools for them. Buying everything to port the heads, the time it takes you, and the gains (which most likely will not be close to lloyds heads) arent worth it and it will more cost effective to get them ported by lloyd. JMHO.
Old Mar 12, 2007 | 11:18 AM
alright thanks man
Old Mar 12, 2007 | 10:04 PM
Ellis's Avatar
I port my own heads. I've done a few SBCs, but not any LT1s yet. My virgin LT1 set is all stripped, cleaned, and sitting on the bench ready to go. I just got a Makita 1/4" electric grinder that I'm really stoked about. I was running my poor little Craftsman 5.5HP compressor ragged using air tools to port with.
Always had satisfying results. One of the upcoming projects is to build a flow bench to measure those results.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
Killer94z
Jan 13, 2015 12:06 PM
Brian-94TA
Jul 31, 2002 02:52 PM
