stock heads information???
Old Nov 3, 2008 | 02:38 AM
SS44Camaro's Avatar
just wondering about some things. ive heard that they earlier year lt1 heads have a little more "meat" and can be ported more than the later years, and lt4 castings even more. also that the stock iron heads flow better than aluminum heads.
guess im just trying to get a little knowlege of lt1 heads. also what is the weight difference between iron and aluminum heads?
Old Nov 3, 2008 | 08:08 AM
user 647483's Avatar
More meat? yes ... a little.
This is a photo of early heads VS later heads. Note the extra material in the earlier design.
Fbodies only came with aluminum heads.
Old Nov 3, 2008 | 08:42 AM
gatorhead's Avatar
I don't know tyhe exact weight differences between the heads, I want to say it is 14 lbs, but I am not positive on that one.
What I do know is:
Earlier castings (374's) had more "meat" as you called it and weighed about 2 lbs more than the later catsings. They didn't flow as good as the later castings but they had more porting potential thus making them the preferred head of choice.
The cast Iron heads flowed better than all of them, but they were considerably heavier and although they could be ported they also were iron which if you had the choice between aluminum or iron you choose aluminum for various reasons including weight and heat transfer.
Here is a nice link to educate yourself a bit better on the differences between an lt1 and an lt4 http://www.grandsportregistry.com/lt1vslt4.htm
Old Nov 4, 2008 | 09:31 AM
SS44Camaro's Avatar
ive seen guys say they were 32 lbs heavier a peice on other forums. i think thats way to much. i see a different number everywhere i go.
Old Nov 4, 2008 | 04:11 PM
blue 79 Z/28's Avatar
i weighed both heads without valves and springs and they were only in the low 60's together if i remember correctly, so id say no to that. maybe a few lbs tops lighter definately not over 30 a side, its not an iron bbc head going to aluminum lol
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
Killer94z
Jan 13, 2015 12:06 PM
Brian-94TA
Jul 31, 2002 02:52 PM
