Stock Fuel Pump GPH
Old Apr 5, 2006 | 01:53 PM
snod83's Avatar
Stock Fuel Pump GPH
I was wondering what kind of pressures and flow rates the stock fuel pump has?
Thanks,
Ryan
Old Apr 5, 2006 | 07:27 PM
OBE1 95Z28's Avatar
Re: Stock Fuel Pump GPH
I believe the stock pump is 190 lph rated at 43 psi.
Old Apr 7, 2006 | 09:27 AM
snod83's Avatar
is the lph liters per hour or is that a typo and supposed to be gph?
Thanks,
Ryan
Old Apr 7, 2006 | 09:37 AM
OBE1 95Z28's Avatar
liters per hour
Old Apr 7, 2006 | 10:02 AM
MeanGreen97Z's Avatar
Liters is what all the fuel pumps I have seen are rated in.
Old Apr 7, 2006 | 08:11 PM
96capricemgr's Avatar
One of the b-body guys actually measured his flow in the car, not sure if it is the same exact pump but it very possibly is.
He got 147lph(38.8gph) at 43.5psi, don't know how old the pump was. The low number could be caused by the restriction of the plumbing besides the 43.5 at the regulator and by the addition of the in tank sock and fuel filter in the stock lines. Also consider a stock pump is likely OLD and should not be trusted to perform to new specs. Also factory wiring often leads to signifigant voltage drop causing low flow, Racetronix makes some nice plug and play wiring upgrades for this.
HectorM52
Jul 30, 2017 11:46 AM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
