Stock fuel line questions
When the fuel lines come into the engine compartment they are plastic. When I looked at the quick disconnectors there is some rubber at the end of the line. What is the transition from the plastic line to the quick disconnectors?
Ryan, wrong part!
Not talking about the little rubber "boots" or grommets. Maybe my fuel lines are different? As I look at them the lines are plastic, then a larger diameter maybe 8" long piece of rubber covers them, transitioning to the quick disconnect.
Mainly what I want to know is the complete fuel line plastic or does it transition to rubber before the quick disconnect.
Not talking about the little rubber "boots" or grommets. Maybe my fuel lines are different? As I look at them the lines are plastic, then a larger diameter maybe 8" long piece of rubber covers them, transitioning to the quick disconnect.Mainly what I want to know is the complete fuel line plastic or does it transition to rubber before the quick disconnect.
Brandon Wittmer
Dec 20, 2014 09:51 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Jul 4, 2005 05:00 PM
