Stock deck height? trying to figure CR
Old Feb 14, 2006 | 10:31 PM
ss#1230's Avatar
hey guys, im trying to use the CR calculator to figure the 62cc trickflows on a stock motor.
anyone know the stock deck height, stock gasket thickness.....?
thanks,
jeremy
Old Feb 14, 2006 | 11:35 PM
1racerdude's Avatar
Re: Stock deck height? trying to figure CR
9.025 nominal on block height. The stock gasket is .049 and a Fel Pro 1074 is .039. Your piston stock is in the hole about .020-.025. Your stock valve reliefs are 7-8CC's.
Old Feb 14, 2006 | 11:57 PM
ss#1230's Avatar
so putting on the 62cc trick flows will only drop my CR to about 10.2?
and running a 62cc head with 21cc dished pistons would drop me all the way to about 8.2?
does this sound right to everyone?
thanks,
jeremy
Old Feb 15, 2006 | 12:06 AM
1racerdude's Avatar
thanks,
jeremy
More than that.Your stock heads are 54CC's with 10.8 stock compression.
Old Feb 15, 2006 | 10:20 AM
Colin91Z's Avatar
I thought LT1s had 10.4 and LT4s had 10.8 because the LT4 has 2 vlave relief pistons vs. the LT1s 4 valve reliefs...please correct me if I'm wrong
Old Feb 15, 2006 | 03:28 PM
marshall93z's Avatar
You're right.
Old Feb 16, 2006 | 12:29 AM
SWINGRRR's Avatar
You should "dry" build the motor and then measure how far down the piston is. Factory deck height is not always perfect. Core shift does happen.
Old Feb 16, 2006 | 12:36 AM
1racerdude's Avatar
Yep ya are right,but .4 in compression don't mean a whole lot as low as you are.
Old Feb 16, 2006 | 12:45 AM
SStrokerAce's Avatar
The decks are usually around 9.020-9.030"
Use the 9.025".... but the pistons are commonly .020-.025" in the hole.
Bret
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
smokin25th
Jan 1, 2015 09:06 AM
