Stock CC on lt1 heads? I keep hearing two answers.
Old Mar 30, 2005 | 07:18 PM
Pasky's Avatar
I hear 58 cc and 54 cc. What is the actual combustion chamber size on 95 aluminum heads?
I always thought the lt4's were 54cc and lt1's 58cc.
Old Mar 30, 2005 | 07:34 PM
96m6lt1's Avatar
Re: Stock CC on lt1 heads? I keep hearing two answers.
they are 53cc,well the two sets i have are they were cc'd this afternoon...they are virgins...........till mr. elliot gets them......
Old Mar 30, 2005 | 07:37 PM
Pasky's Avatar
Damn it, I ordered -3.4cc flat tops assuming stock heads were 58cc. This is just great, now I will have a 11.6:1 Compression ratio. ARGH
Old Mar 30, 2005 | 08:21 PM
Pasky's Avatar
Damn it, which is it?
http://web.camaross.com/forums/showt...stion+chambers
Gmpartdirect has lt1 heads listed as 58cc:
http://www.gmpartsdirect.com/perform...CATID=856.html
Old Mar 30, 2005 | 08:41 PM
97Z-M6's Avatar
mine were 54 after i got them back from loyd
Old Mar 30, 2005 | 08:42 PM
Pasky's Avatar
Well....****.
Old Mar 30, 2005 | 09:53 PM
ajschult's Avatar
I always thought it was 54. It is my understanding that with good tuning that compression would be fine on 93 octane.
Old Mar 30, 2005 | 10:40 PM
sbs's Avatar
sbs
Says 58 here also:
http://www.carcraft.com/techarticles/116_head_chev/
Old Mar 30, 2005 | 11:17 PM
1racerdude's Avatar
The ones I have seen are 54 and you should be fine with anykind of cam with that compression.Your DCR is what matters not static compression.
Old Mar 30, 2005 | 11:20 PM
AM91Camaro_RS's Avatar
i just did a set of aluminum heads for my friend's 96. i cc'd the chambers and got right at about 57cc on all of them and i polished them. so, i did a little grinding in them but i'm pretty sure i didn't remove much material. i was happy that they were all extremely close to the same cc without having to touch anything up!
Old Mar 31, 2005 | 12:05 AM
ss#1230's Avatar
ive heard 58 too.
ive also heard LT-4 = 53.4 , or something like that.
and LT-1 are 56.something.
i think people round the numbers and call LT4s 54cc and LT1 56cc.
i dont see the LT-1 heads being 54 or less, if that was true then the LT-4 would have to be as little as 52cc. if you change the head on and LT1 to LT4 heads your compression goes from 10.5 to like 11.1:1
one of the site sponsor should know. like combination motorsports......
Old Mar 31, 2005 | 12:25 AM
94FBIRD's Avatar
Well, I had my chambers measured by a machine shop because I couldn't get a straight answer either. They were exactly 54cc.
Old Mar 31, 2005 | 12:31 AM
ss#1230's Avatar
well then what friggin size are LT-4 heads???????
BTW, summit advertises their CR on their rebuild kits for the LT-1 with 58cc heads.....so is the unsuspecting guy that is rebuilding his stock LT-1 gonna have a lot higher CR????
Old Mar 31, 2005 | 12:47 AM
Pasky's Avatar
Thats what im saying, even gmpartsdirect says they are 58cc. I hope I didn't get the wrong fricken piston size.
Old Mar 31, 2005 | 02:21 AM
sbs's Avatar
sbs
Here it says "a bit more than 53"
http://www.chevyhiperformance.com/techarticles/4606/
The pattern looks like there's a 58 number from some official source, but measured numbers are more like 53-54.
