stock cam #'s?? and what cam is best for me?
Old Oct 22, 2003 | 08:19 PM
pwrtripta's Avatar
hey guys just wondering if anyone has some #'s and specs for a stock cam in a lt1?
my 2nd question, i have a bolt on car, LT's, lt4 intake mani, 58mm tb, CAI, exhaust, pulleys, etc etc...STOCK HEADS!! what cam is best for me? what do you think of lt4? if not please give me a rough description on what to look for , i would like to get 1.6 rockers with whatever cam i get.
Old Oct 22, 2003 | 08:59 PM
1995redZ28's Avatar
not sure on the specs of the stock cam. but if you are looking for something reasonable id def. say go with the HOTCAM. its very popular on this board. do a search and u will find a ton of information. the HOTCAM comes in a KIT with the 1.6 rr's and springs.
i have a thread a few posts up with a dyno of my 94 with the hotcam. check it out. and def. do a search! you will find what you are looking for!
welcome to the board!
Old Oct 23, 2003 | 11:59 AM
pwrtripta's Avatar
lt4 hotcam
i am looking into the lt4 hotcam kit, does it include lifters, and pushrods, or timing chain? if not do you guysd kno roughly how much i should to spend including these parts without install ?
Old Oct 23, 2003 | 12:35 PM
94formulabz's Avatar
Lets define some more of what you want from this cam.
Are you looking for max effort?
What rpm are you comfortable with for a shiftpoint?
How much low end driveability are you willing to give up?
Are you looking for an agressive choppy sounding idle?
When driving in traffic what rpm do you currently shift at?
When highway driving do you use 6th gear?
Are you going to swap rear end gears?
Edit,
This will give you an idea of the stock cam specs 230/203 is a typo for the 94-95 cam.
Old Oct 23, 2003 | 12:38 PM
RallyRed701/2's Avatar
i didnt know you could have an lt4 intake with stock heads... what did you have to do to get that to work???
Old Oct 23, 2003 | 12:46 PM
Re: lt4 hotcam
maybe 400 dollars. How many miles are on your motor? Many people reuse hydraulic lifters if there milage is reasonable. If you have a 93/94 you already have hardened pushrods and might consider reusing them. Timeing chain, or timing set? The chain and gears wear together slightly so with higher mileage you cannot replace just the chain.
canbaufo
May 25, 2015 12:01 PM
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
chuyz28
Feb 19, 2015 12:50 AM
Queens94z28
Dec 20, 2014 09:11 PM
chuyz28
Nov 25, 2014 11:14 PM
