Stock cam
Old Jul 5, 2004 | 10:59 PM
  #16
ThirdGenLT1's Avatar
thanks, I think you've put me over the edge. The cc305 is the right cam for me!!!
Old Jul 5, 2004 | 11:19 PM
  #17
bdc95ta's Avatar
you could always go....custom!
-b
Old Jul 5, 2004 | 11:39 PM
  #18
jchevy's Avatar
I just did a xe218/224 on a 112lsa in my car and could not be happier with it. Still drives like it did with the stock cam but pulls so much harder. I went with an xe grind b/c the power comes on sooner and i didnt want to rev my stock bottom end much past 6000 rpm.
Also this is supposed to be one of the best cams for stock heads.
Old Jul 6, 2004 | 12:23 AM
  #19
crAzy95z28's Avatar
Originally posted by kyzar24
go with the crane 210 224 112 lsa great cam sleeper and makes great power 2,000 6,200
i have one....without ported heads...and it sounds great and is great....im very sastisfied with it...havent dynoed yet, but hopefully soon....got tunes though..
let me know what you wanna do..
Old Jul 6, 2004 | 08:40 AM
  #20
stereomandan's Avatar
All of the cams mentioned here are very similar. They are all great for stock heads (XE218/224, CC305, Hotcam, 210/224...)
My view of each camwith headers, CAI and catback)
XE218/224: (Expect about 335rwhp/335 rwtq)
Possibly the best off the shelf cam for stock heads if you don't want to rev to the moon. Excellent throttle response, gas milage, and power. TQ comes on about the same as the other cams, but peaks a little higher and drops off fast at high RPM (>6200 rpm) You have to buy good springs for the XE grind.
CC305: (Expect about 335rwhp/335 rwtq)
Great cam. See consistantly good times from people who have it. A little easier on the valvetrain than the XE grinds, and can rev a little higher than the XE218/224 if you want without floating the valves.
Hotcam: (Expect about 328rwhp/328 rwtq)
Great all around cam. You can spin this to the moon with it's lazy ramps. Easy on the valvetrains and has a super flat TQ curve.
Crane 210/227: (Expect about 320rwhp/325 rwtq?)
Excellent low end TQ and just enough top end to keep you happy. Some very fast cars with this cam. A good sleeper cam with great daily driving characteristics.
Dan
Old Jul 6, 2004 | 08:41 AM
  #21
Have you dynoed that cam? I keep trying to find a dyno of it without success.
Dan
Old Jul 6, 2004 | 09:05 AM
  #22
Valkyn71's Avatar
Alot of guys get hotcams to run very quick on stock heads. I would definetly get something smaller than the 224/230, which kills your power under 2800 or so.
Im getting a custom cam with some more low end while i do my head swap
Old Jul 6, 2004 | 11:50 AM
  #23
crAzy95z28's Avatar
the cam i have has great low end trq.....has way more than the stock one and it has upper trq too....i now need some dang drag radials....and no i haven gotten it dynoed..
Old Jul 6, 2004 | 05:41 PM
  #24
Would their be any advantages of getting the cc305 ground on a 112 LSA?
From the sounds of it I'll be happy with either the cc305 or the 502. I'm probably going with the 305 because it's easier on the valvetrain, and I like how it sounds... could use a little more lope though which is mainly why I'm interrested in the effects on the 305 on a 112lsa.
thanks for all the help though!!!
Old Jul 6, 2004 | 05:54 PM
  #25
TransAm-Z's Avatar
so do you guys think it would be beter to run the cc305 with 1.5 RR's or the hot cam with 1.6 RR's? I was dumb and bought the Crane 1.5 RR's a while ago, and right now am looking into the Hot cam kit due to the $$ savings (can't afford another $300 set of RR's). I also have stock heads and stock manifolds.
Old Jul 6, 2004 | 06:09 PM
  #26
They would be almost identical set up that way, but the Hotcam will still have more lift with 1.6 RR's vs using 1.5 RR's on the CC305.
Out of those two choices, I would go with the Hotcam kit with the 1.6 RR's.
Dan
Old Jul 6, 2004 | 06:11 PM
  #27
You'll get a little better high end TQ/HP with the 112 LSA vs the 114 lsa, but you will loose a tiny bit of low end TQ.
The idle will be slightly more noticable with the 112 LSA.
Dan
Old Jul 6, 2004 | 06:34 PM
  #28
I'll probably just get it with the 114lsa, low end torque is my main concern and I'd rathar keep as much of it as I can!
Thanks for all the help in picking my cam!!! It's not easy to do with so many options available.
Old Jul 6, 2004 | 07:27 PM
  #29
jchevy's Avatar
If you are looking for low end then you want an XE grind. You also wont rev one of these as high. I highly recomend the 218/224.
Old Jul 6, 2004 | 08:09 PM
  #30
can I use my stock lifters with the 218/224, provided they are in good shape?
other parts i'm selecting to go with my swap:
- cm612 springs, no matter which cam I decide to go with.
- 1.6 pro magnum rocker arms (self aligning)
- I'll figure pushrods later.
Note: iron heads!
anyone see any problems with components used?
later, matt
One last: I saw some great dyno #'s from someone using this cam (218/224) on a 111 LSA, will that make that big of a difference compared to the normal 112lsa it's ground on. Will the torque still come in before the cc305 when ground on a 111lsa?
