Stock Altenator Amerage?
Old Apr 7, 2009 | 08:45 PM
94 Assault z28's Avatar
hey i have a 94 camaro and i was wondering if anyone knows what the stock amperage is on the alternator casue all the ones i see are 140amp and 200amp so i wanna see if i can get away with a 140 or if i need the 200. thanks
Old Apr 7, 2009 | 08:54 PM
Kevin Blown 95 TA's Avatar
Why would you need 200 amps? Do you have a lot of stereo gear or something?
Old Apr 7, 2009 | 08:59 PM
mdacton's Avatar
the one with a stud on the back is a 140....
the one that has a little tinny bolt with a funny conector is a smaller amp one from the earlier cars. Pretty sure 94 had that one.
Old Apr 7, 2009 | 09:03 PM
twcblackhand6970's Avatar
i had a 94 that was studded, think they said earlier ones had the 93 version.
Old Apr 7, 2009 | 10:02 PM
94s could have a 124A (bolt connecting the battery cable and metal fan) or 140A (stud/nut for connecting battery cable and plastic fan).
Old Apr 8, 2009 | 12:31 AM
marshall93z's Avatar
What about 93s?
Well, by reading shoebox's post, looks like 93s are 124A... at least MINE is.
Old Apr 8, 2009 | 12:37 AM
8cylinders>4's Avatar
yup that is correct, mine is one of the 94's that came with the 140 amp alternator
i read at one time that if the car had the dual fan setup where both fans would run on low speed and then both on high speed you would have the 140 amp alternator
if you had the earlier fan setup you would have the 124 amp
Old Apr 8, 2009 | 04:42 AM
madhatter's Avatar
You can use a 140 on a 124 car.
Old Apr 8, 2009 | 08:19 AM
i know i can use whatever alternator amperage its just everything in my car was dimming BAD like the radio would shut off when the window switch was pressed. so i was seeing what the stock amperage would be so knew how much i was in the clear with.
Old Apr 8, 2009 | 08:49 AM
Even a stock 124A alt should be able to power your normal, stock accessories.
Old Apr 8, 2009 | 05:09 PM
well when i replace things i try n get things so that i don't have to expand on down the line of upgrading so if 124 was doing it id get the 140 just so down the road i know it can handle what i throw at it n not end up getting banged twice for it.
HectorM52
Jul 30, 2017 11:46 AM
canbaufo
May 25, 2015 12:01 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
