Stock A4 Trans-how Much Power?
Old Jul 27, 2003 | 11:42 AM
fordkiller94's Avatar
Question Stock A4 Trans-how Much Power?
Does anyone here have an idea of how much power or mods can be done to a 94 LT1 before I'll have problems with the stock trans? I am staring to get more involved with the car but do not want to damage the trans or rear diff. Can a stock A4 take a shot of nitrous wth a stock convertor, maybe 100 shot? Just wondering what you guys have run into with your A4's and bolt ons.
Thanks Fordkiller
Old Jul 27, 2003 | 12:39 PM
ishz28's Avatar
When my car was stock I did some pretty stupid things in it and the tranny held up fine. After my rebuild (355, 11:1, 2.02/1.60, 1:6 Crane rockers, dual race springs, retainers, etc, Crane 210/224 #104227, flat top pistons, pink rods, stock chamfered? crank, a lot of suspen/chassis mods, etc) No dyno, but guess-ta-mated at around 370 RWHP. I've toasted two trannies and having problems my third. Also, broke a pinon gear tooth with Richmond 3.73's.
Old Jul 27, 2003 | 03:42 PM
DiabloZ's Avatar
377rwhp, stock trany with stock TC and 100K mile on it. It held up for awhile and is still O.K., But every time I have it to the track it slips worse and worse. It will be shot soon.
Old Jul 27, 2003 | 07:27 PM
Does not sound like these 4L60E trans like the bolt on power too much!! Anyone know what to do to them that doesn't cost $2,000.00 to make them stronger? Just wondering...
Old Jul 27, 2003 | 07:57 PM
DiabloZ's Avatar
That's the question I have on my mind.. I've just started to try to figure it out.
Old Jul 27, 2003 | 10:48 PM
Where is a trans tech when you need one that will work for a case of beer????
Old Jul 28, 2003 | 12:37 AM
QCKZ28's Avatar
another voucher that 4l60E cant take much more than stock, my heads/cam combo broke the tranny on the WOT run. i found that cmotorsports.com was the solution to my problems.
jesse
Old Jul 28, 2003 | 01:56 AM
Kain's Avatar
Depends on how many miles are on it, how often the fluids were changed, and how abusive the driver was.
I've seen them brake on bolton cars with less than 300 rwhp. Then again, I've seen LS1 head and cam cars (low 400 rwhp) go for awhile before breaking them.
Old Jul 28, 2003 | 02:26 AM
QCKZ28's Avatar
that brings up a question i have. i have read about the ls1 A4 stock tranny taking alot more hp than our lt1 A4 stock tranny before it breaks, are there any differences in the ls1 version of the 4l60e?
jesse
Old Jul 28, 2003 | 02:33 AM
RedPhenx's Avatar
i think 1-3 gears are a little different, which will obviously change the amount of actual power going through the tranny, dont know for sure though
Old Jul 28, 2003 | 04:11 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
they were made to handle a maximum of 350 lb. ft. of TORQUE.
torque power is how trannies are catagorized...
stock... you are probably putting out 330....
if the stock tranny holds up for a while on a stock car that receives even a small amount of abuse... your lucky...
but to answer your question...
a very small amount of mods will put the tranny over its limits... expect problems.
HectorM52
Jul 30, 2017 11:46 AM
canbaufo
May 25, 2015 12:01 PM
dale3in98
Feb 14, 2015 12:18 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
