Still smoking.. pictures inside!
Old May 14, 2005 | 01:45 PM
kainZ's Avatar
Angry Still smoking.. pictures inside!
For those who have been following my saga, I got the car running again after fixing all the PCV and cooling problems, and a few other misc. things, but it's still smoking.
The smoke definetly has a bluish tint. It's definetly oil. I'm no longer overheating, so I'm pretty sure it's got to be an oil leak.
The valve stem seals looked okay to me, but maybe I put the one I took off back on wrong, or maybe they just weren't.... Or, maybe I have bad piston rings..
Anyway, the smoke is coming out of the missing air diverter on the drivers side and out of the tailpipes.
I took some pictures of the seal before I put the spring back on, and of the smoke.
It should also be noted that I felt like my car had less power and worse throttle response when revving... Also, it was ticking pretty badly.. Maybe I didn't lash the valves far enough (didn't tighten the rocker far enough)?
Anyway, here are the pictures:
http://www.rpi.edu/~roghab/camaro/new_problems/
I'd much prefer it to be valve seals, as then I wouldn't need to rebuild.. but I'm not really sure at this point.
I'm going to go take it for a test-drive down to the parts store.. I hope someone has some ideas based on the pictures..
Old May 14, 2005 | 02:09 PM
slopokrodrigez's Avatar
Re: Still smoking.. pictures inside!
Hmmmm, ticking and smoking. What weight oil are you using??? Have you done a leak down test?
Old May 14, 2005 | 02:16 PM
kainZ's Avatar
M1 10w30.. I'm gonna change that out for the thicker 0w30 later on, I think that might help. I'm also thinking about throwing some marvel mystery oil in it.. I think that the rings are probably the issue, as it sat for a year, and had the heads off for part of that time. The valve stem seals looked fine. But I will do a leakdown test and compression test once I get the chance.
Also, I don't think I could get this much smoke from valve stem seals, as the oil there isn't pressurized.
1970judge
Cars Wanted
May 23, 2015 11:39 PM
carl.froehlich
Mar 13, 2015 12:38 AM
capebuf
Jan 13, 2015 07:22 PM
squarehead
Nov 21, 2014 08:02 PM
0toinsanein5.4sec
12
Aug 28, 2002 12:35 AM
