still over heating??
Old Feb 25, 2012 | 06:23 PM
javi805's Avatar
i need some tips if anyone can help, i installed a new waterpump with new thermostat and when i let the engine run for a few the temp goes all the way up...and i put 11/2 of dex cool coolant...any tips would help alot. thanks..
Old Feb 25, 2012 | 06:31 PM
moparman's Avatar
Re: still over heating??
Did you bleed the air? Use the correct LT1 t-stat?
Old Feb 25, 2012 | 06:42 PM
javi805's Avatar
i did not bleed it yet but i did use the correct thermostat
Old Feb 25, 2012 | 07:05 PM
englundjd's Avatar
you gotta bleed it or it will overheat/run hot
Old Feb 25, 2012 | 09:34 PM
JFR's Avatar
JFR
Did all that and found out head gasket was blown on 2 cylinders. Did not run bad, just aways had temp problems when sitting in traffic. Did seem to use water, but none in oil.
1995 lt1 79,000 miles on it. Now did valve job and new gaskets.
Hope it is not your problem.
I forgot, first thing I did was bleed, bleed, it is a pain.
I assume my problem was the water was steaming out the exhaust from the 2 bad cylinders. When I took it apart, those pistons and all around were clean, clean ,steam cleaned.
How about the heater core, that might have a leak up front.
Old Feb 26, 2012 | 12:05 AM
mrmint69's Avatar
Do you know how to properly bleed the system? If not, do a search on here.
Old Feb 26, 2012 | 05:23 PM
frankzlt1's Avatar
I wouldn't have ran Dec cool I would've put the green stuff in it instead. Dec cool is some nasty stuff it will eat out the inside of the motor and aluminum if not taken care of right.
Old Feb 26, 2012 | 06:16 PM
moparman's Avatar
I've been running DexCool for 16 years without any problems.
Old Feb 27, 2012 | 02:35 PM
Notsue's Avatar
Bleed, bleed, bleed.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
CARiD
Sep 30, 2015 05:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
damnyankee36
Sep 9, 2015 07:06 PM
