still looking for help W/sc lt1
Old Oct 1, 2004 | 02:53 AM
97ws6ta's Avatar
has ported polished heads ,intake ,cam ,12 lb s trim 255 pump 50 lbs injectors pulls like hell to 5200 rpm 408 rwhp ,then its done. runs good until then. list of new parts is crazy. I have tried everything I can think of . All Ideas would be great thanks Larry
Old Oct 1, 2004 | 07:38 AM
teke184's Avatar
Re: still looking for help W/sc lt1
you've tried the coil and checked all the wires?
Old Oct 1, 2004 | 08:43 AM
agrsiv95's Avatar
Isn't there something with the MAF and OBDII cars that when the MAf maxes out the car falls on its face. I have a 95 OBDI so I never worried about. If I remember correctly, ATI makes something to combat the MAF maxing out.
J
Old Oct 1, 2004 | 08:50 AM
slimdawson's Avatar
Yep, ATI makes a code buster for the obdII cars. It keeps the high MAF code from setting. Not sure if that is the problem.
A little more info on the symptoms would be helpful. Does it shut off immediately? Does it break up? Will it continue to pull past that only roughly? If it shuts off at exactly 5200 rpms every time, it is most likely electrical. Check your program.
My car was cutting off around 4500 about 30% of the time. I regapped my plugs to .035 (I am running 8lbs) and haven't had the problem again yet.
Tell us a little more info if you can.
Old Oct 1, 2004 | 12:05 PM
97ws6ta's Avatar
it breaks up after 5200 if you shift every time at 5200 runs great has new plugs ,opti ,fuel pump, filter ,injectors ,msd coil, 6abox,it will run past that but not good feals like a clogged cat ,but there are no cats on the car
Old Oct 1, 2004 | 01:47 PM
slimdawson's Avatar
Take the MSD6a off and try. I have known of quite a few to cause problems like that.
Old Oct 1, 2004 | 03:12 PM
BlownF1's Avatar
What are you running for intake ducting to the blower? Could it be the collapsing "dryer ducting" issue?
Old Oct 1, 2004 | 04:25 PM
97ws6ta's Avatar
I did that I had a crane hi6r so i tried the msd same results and the ducting is fine !!
Old Oct 2, 2004 | 12:40 PM
slimdawson's Avatar
Does it do it in any gear? Will it do it in neutral or only under load?
Have you checked the fuel psi while running it?
I wonder if you are running into any knock.
Old Oct 2, 2004 | 07:00 PM
97ws6ta's Avatar
it seams to rev fin does it in all gears fuel psi is 60 wot
Old Oct 3, 2004 | 02:40 AM
slimdawson's Avatar
Are you still running stock timing?
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
