still having starting issues!!!
Old Apr 24, 2004 | 03:38 PM
1994TransAm's Avatar
hey guys,
today i pulled the old fuel pump..... installed the new one.... right now i'm letting the glue seal and then it goes in.
just for fun sake i hooked the car jumper to the old fuel pump and it RAN!!!!!!!!!!!!!!!!!!!
so what the heck is my problem.....
i had a new fuel pump relay put in the car... still didnt start.... i know my wires are getting juice!!!!
i donno why this wont start!!!
Old Apr 24, 2004 | 04:01 PM
ChevyIron's Avatar
I would double and triple check to make sure all connections opti coil etc ect are plugged in.One of the connectors could have a losse conn.Also check your ground wire make sure goodantighty.Best of luck to you.
Old Apr 24, 2004 | 04:05 PM
raceryan's Avatar
Dumb question, but is the starter solonoid clicking, and/or engine cranking? Might wanna beat on the starter with a crowbar and try it.
Old Apr 24, 2004 | 04:12 PM
car turns over.... and i've put a test light on the wires.... opti is new... the car did run for 5 mins after the cam installl then died.
i didnt ahve any fuel pressure..... i unhooked the fuel lines and trned the key... nothing came out...
put a new fuel pump relay in... nothing still
tried to prime the pump with the primer near the PCM.... nothing....
i dont hear any hum from the fuel pump when i turned the key...
put the new pump in today.... gonna wait thill tommorow
Old Apr 24, 2004 | 04:30 PM
Your old pump may have been temporarily frozen up. All the jostling of removal might have freed it to the point of being able to run when you hit it with voltage. That does not mean it wouldn't conk out again after running for a while.
Scottyboy
Feb 11, 2015 10:28 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Alex Barnes
Jan 24, 2015 10:21 PM
David Dorris
Jan 17, 2015 08:10 PM
