still fighting Primary Tube leak on LT
Old Feb 23, 2004 | 11:49 AM
93transam1234's Avatar
Well i have tryed just about every thing i can think of to get rid of this leak, It is the slip fit tube on the JetHot long tubes.
Here is what i have tryes
High Temp Furnace cement (cracked over time)
RTV high temp (didnt even work )
RTV & clampted it (now it started leaking aging
I dont want to pull the header off any one else got a fix i can try?
Old Feb 23, 2004 | 04:38 PM
SlickBlack Z's Avatar
Maybe you could try some of that high temp exhaust repair tape, then put a band clamp over it. I did this to seal my y-pipe connections...works great.
Old Feb 23, 2004 | 05:40 PM
speed76demon's Avatar
Where can you get the high temp exhaust tape??
Old Feb 23, 2004 | 05:47 PM
ChevyIron's Avatar
Did you use the right clamp it should be the 13/4 t clamp i believe its called summit has them you can snug it up real tight should seal with no other stuff to use.
Old Feb 23, 2004 | 05:55 PM
97 RedSS's Avatar
I tried everything also..Only thing that worked was welding it up
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
BigWil
Mar 29, 2015 12:24 PM
Jul 4, 2005 05:00 PM
MattSLONOMO
Aug 30, 2002 01:45 PM
