Step on it=hesitation?HELP!
Old Jul 24, 2003 | 11:03 PM
SpeC's Avatar
ok my car has been feeling weird lately. I put the pedal down and it feels like i lost about 25 HP. Its decent when i put the pedal down a little..
but when i floor ( step on it a lil) the car kind of hesitates and then the power comes in. It kinda of stumbles or somthing. Like stumble-stumble- then the power kicks in. (yet it doesnt feel like it pulls like it used to?) It feels like when my spark plugs went bad. But i got those replaced while ago.
what could it be? I just got the tranny serviced 2 weeks ago, the car tuned up 2 years ago (spark plugs and all), and the air intake is fine? Please tell me what it could be. THanks in advance.
Old Jul 25, 2003 | 07:36 AM
96ZRide's Avatar
If it runs fine at part throttle, but stumbles on WOT, I'd first suspect a fueling problem.
Check your fuel pressure. Good luck!
Old Jul 25, 2003 | 08:03 PM
SpeC's Avatar
some1 told me that i should change my fuel filter. How would i do this?
Old Jul 25, 2003 | 09:50 PM
zuluman13's Avatar
was ur a/c on it takes off about that much hp but it shuts off at wot the only ything i can think off is that it takes a second to shut off then u get full power its worth a shot to just try it with the a/c off.
Old Jul 25, 2003 | 10:24 PM
93RedDevilZ28's Avatar
Did you notice if the problem gets worse with an increase in temperature?
I have the same problem, mainly from 1100-2000rpm's.
It seem to get worse with heat.
I'm going to replace the wires first and see if maybe that's it.
Old Jul 25, 2003 | 11:45 PM
jasons93z's Avatar
The filter is right under the drivers side underneath. Its real easy to change.
Old Jul 26, 2003 | 12:29 AM
Fatdog's Avatar
Cool
Coil wire,plugs,wires.My02
Formula Steve
Sep 19, 2023 08:31 AM
WobblySausage
Oct 7, 2015 02:44 PM
greenzee28
Sep 25, 2015 04:29 PM
Bxlt1
Sep 17, 2015 08:31 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
