steering wheel linkage
Old Mar 22, 2005 | 06:02 PM
slverbullet's Avatar
okay, i'm trying to install my steering wheel linkage. are there any tips to getting this thing back on easily? ive got the top part to slide on pretty easily. now i cant get the bottom part to sit into place. it would be nice if it could slide on just a little bit so that i could use a pipe or screwdriver and a rubber mallet to tap it on. i just cant get it started. should i try to put that end on first. seems that if i do, i would have just as hard, if not harder time putting the top piece back on. hmm, just looking for suggestions and some inside tips. thanks guys.
Old Mar 22, 2005 | 10:25 PM
OBE1 95Z28's Avatar
Re: steering wheel linkage
The overall length of the linkage is adjustable. The bottom "leg" has a slider built into it. It usually rusts in place. Use some penitrating oil and tap it with a hammer. This adjustment should allow you to reconnect the linkage without any trouble. Make sure you lock your steering wheel in place. If you don't, you risk breaking the "clock spring" coil wire for the ABS; don't ask how I know
jasonduaine
Jun 4, 2015 09:29 AM
CheckOutMyRoost
May 23, 2015 02:33 PM
nikko
Apr 28, 2015 10:05 AM
Airplanedoc
Feb 1, 2015 07:14 PM
ro2207
Dec 4, 2014 06:18 PM
