Steering wheel column adjustment
Old Jan 28, 2013 | 03:22 PM
MathalomuleM31's Avatar
Hi! I have a 94 camaro v6 body that I recently swapped the engine out with a 96 v8. Everything's done and it was hard work but I'm glad I did it... I have a small issue though, the steering wheel column is rubbing against the shorty headers I have on. It was pretty bad and noisy till I got an alignment done and that helped Alot. However it still rubs a little. My mechanic said there wasn't much he could do about it. I was wondering where I could get this solved? Simply a place that does alignments? Has anyone had any experience with this kind of thing?
Old Jan 28, 2013 | 04:05 PM
Re: Steering wheel column adjustment
You could try loosening the three bolts that hold the column to the firewall and try shifting the column over, then re-tightening the bolts. There might be a little play to be had, there.
Old Jan 30, 2013 | 12:29 AM
ZZ's Avatar
ZZ
You can ding the header for clearance.
Fastbird93
Apr 9, 2016 07:01 PM
nikko
Apr 28, 2015 10:05 AM
Airplanedoc
Feb 1, 2015 07:14 PM
ro2207
Dec 4, 2014 06:18 PM
