Steering shaft Linkage
Old May 3, 2005 | 02:13 AM
Johnnynsac's Avatar
Just a question that I've been meaning to ask for while now. My steering shaft came loose since I added headers a few years back. Found the problem but don't know the fix.
http://community.webshots.com/photo/...46143656lNLgNl
This is not from my LT1 but it's close enough since I suck with computers.
It's the black jacket thats close to the firewall. It hold the steering shaft in place. It's like a bearing or adapter that holds the shaft in place but instead the white plastic adapter and everything else inside the black jacket melted and fell out. It's hollow inside there now and my shaft has major play. Steering wheel also has play and vibrates when hitting the brakes.
I'm thinking it's number 86, 87, 88, and 89 that I would probably need?
http://shbox.com/1/steering_column_exploded.jpg
I'm not 100% sure if these are the parts I need.
Thanks for any help guys and gals.
Old May 3, 2005 | 02:17 AM
'94 Bad A Z28's Avatar
Re: Steering shaft Linkage
Couldn't tell ya 'cause I can't see the first pic that you posted.
Old May 3, 2005 | 02:34 AM
There is a way, but I don't remember how... I don't use webshots for anything.
Old May 3, 2005 | 02:44 AM
Johnnynsac's Avatar
Ok, kind of fixed it but with someone elses pic. Hope it resembles what I'm talking about. 94 Bad A Z28, the reason why the first pic didn't show up is because it takes 24 hours for Webshots to show new downloaded pics on there data base. My fault
Old May 3, 2005 | 03:43 AM
Johnnynsac's Avatar
I'm thinking maybe a whole new jacket may have to be installed.
http://shbox.com/1/steering_column_check.jpg
I hope you don't mind me using your pics Shoebox.
Ericksd
Jan 20, 2016 06:07 PM
colts0455
Sep 27, 2015 01:07 PM
autoxr166
Sep 25, 2015 04:21 PM
Daluchman1974
Sep 11, 2015 06:12 AM
rideordie
Sep 7, 2015 08:22 AM
