Steam vent tube seals.
Old Jun 28, 2006 | 04:03 PM
sssalah's Avatar
Has anyone tried using copper washer instead of the stock seals for the steam vent tube. I’m having a hard time getting new ones because they’re out of stock at the dealer.
Old Jun 28, 2006 | 05:54 PM
96SSM6's Avatar
Re: Steam vent tube seals.
I just did heads on a Z28 and used regular oil drain plug washers and a little copper spray. No leaks so far.
Old Jun 28, 2006 | 07:01 PM
Guest47904's Avatar
Guest
All GM dealers have the availability for next day delivery???? So what's the problem?
Old Jun 28, 2006 | 07:05 PM
NVetro's Avatar
You can get them in the self help section of autozone, pepboys, advanced auto: Its in those red packages hangin on the wall that say "HELP!" on them, they have bolts, and all that jazz...they are called crush washers, and they have lots there. Look for them, thuogh i got mine from the dealer, I would also use those, remeber one before and after the steam fitting on the head, 2 on each side for a total of 4. Also make sure to put some thread sealent on those bolts to stop leaks, same sealent u use for water pump bolts.
Old Jun 28, 2006 | 09:29 PM
anaik's Avatar
Have to use one of these to get to Bahrain overnight.
http://www.dfrc.nasa.gov/Gallery/Pho...97-43902-1.jpg
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
drt
Sep 27, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
Jul 10, 2015 02:23 PM
