Steam Pipe A/C Seals
Old Jun 18, 2011 | 10:53 PM
GMC5.3's Avatar
Ive searched that people buy these a/c seals and i just wanted to double check that its the right package, im still having a leak through my steam pipe on my driver side. Also i broke my oil pressure sending unit, is this something i have to get through the dealer, autozone couldnt cross gm numbers on it. Thanks
Old Jun 19, 2011 | 06:17 AM
bw_hunter's Avatar
Re: Steam Pipe A/C Seals
No, those aren't correct. The seals in question go between On the back of the compressor and look like metal washers with a rubber center.
I know AutoZone has them as I just bought some....
Old Jun 19, 2011 | 07:02 AM
ACE1252's Avatar
Autozone has the oil pressure switch.
http://www.autozone.com/autozone/par.../N-j4uzyZ93xnq
Your seals for the steam pipe should look something like this....
Old Jun 19, 2011 | 11:24 AM
GMC5.3's Avatar
thanks and just to clarify, i need a special 1-1/16 size socket to get the sensor off right? It looks like i may not need it does this whole piece just thread into angle fitting #1?
Old Jun 19, 2011 | 08:23 PM
OBE1 95Z28's Avatar
It's a special socket in that it's is deeper that a standard socket. The sender threads into the angle fitting.
Shoebox has a photo here: http://shbox.com/1/oil_pressure_sensor.jpg
Old Jun 20, 2011 | 09:42 PM
GMC5.3's Avatar
Thanks, i saw shoebox's site and picture, i just wanted to make sure that the sensor threads into angle fitting #2 with is the round portion and not the angle fitting that goes to the block. I just but brand new oil and i want to make sure i dont have to touch angle fitting #1 so i wont have oil everywhere.
Old Jun 20, 2011 | 10:21 PM
ACE1252's Avatar
Oil pressure switch socket....
http://www.autozone.com/autozone/acc...er=141490_0_0_
Also, you need 4 seals for the steam pipes...two per side.
Old Jun 20, 2011 | 11:23 PM
Did you see his pic with the two angle fittings? Sensor screws into Angle Fitting 2. Angle fitting 2 screws into Angle fitting 1. Angle fitting 1 screws into the top of the block. If the engine isn't running, you aren't going to get oil pouring out no matter which part you unscrew.
http://shbox.com/1/op_sensor.jpg
Old Jun 22, 2011 | 08:04 PM
GMC5.3's Avatar
Thanks for taking the time to look it up
Injuneer thank you also, i did see shoebox's pic, its really the only reason i knew the lingo "angle fitting 1 and 2" i just wanted to double check to prevent oil everywhere.
Can you both tell me if this is causing my leak through my steam pipe, notice the bolt on the left, its thread is a little smashed in. Just to clarify, i did have the correct seals on the steam pipe before i tried the a/c and it still leaked
HectorM52
Jul 30, 2017 11:46 AM
AlaskaZ28
Jun 26, 2015 11:38 PM
KamikaZ28
May 28, 2015 12:45 AM
Jazsun
Dec 29, 2014 12:14 PM
