Steam Pipe
Old Aug 7, 2011 | 01:28 PM
PureXTZ's Avatar
Steam Pipe
How much fluid should be flowing through the steam pipe a slow trickle or a fast steady stream?
Old Aug 7, 2011 | 02:21 PM
Re: Steam Pipe
There should be a decent stream flowing into the radiator at idle.
Old Aug 7, 2011 | 02:56 PM
96capricemgr's Avatar
Re: Steam Pipe
Yes a decent stream is normal but really long as there is more than a dribble it should work fine as it is really to purge air and steam bubbles, doesn't need to flow a lot of liquid to accomplish that.
Old Aug 7, 2011 | 03:02 PM
Re: Steam Pipe
The factory must expect it fo flow... in 95 they routed that line through the throttle body before sending it to the air separator in the radiator. I have a second coolant temp sensor in the steam line before it dumps into the radiator, and it reads the same as the sensor in the head.
G-BODYT56
Jan 14, 2022 11:14 PM
n2oblkz
Oct 12, 2015 01:53 AM
football4life
Oct 4, 2015 07:48 AM
Ks0209
Oct 1, 2015 07:32 AM
greenzee28
Sep 25, 2015 04:29 PM
