Steam line cracked
Old Feb 5, 2008 | 09:38 AM
gecole80z's Avatar
Steam line cracked
94 lt1 formula a4
After removing the heads to replace the headgaskets I discovered a crack in the tubing that crosses over the back of the block from head to head. What is the recommended fix for this? Would rubber tubing be good enough or do I need to replace with a complete new tubing assembly? Do people block these off or are they a must have for the survival of the heads?
Old Feb 5, 2008 | 09:55 AM
You need the steam line to insure the removal of air and vapor bubbles from the back of the head. Failure to remove will result in hot spots. Typically, the last two cylinders (#7, #8) will run hotter than the others, and may result in detonation, or force you to tune "down" the entire engine to accomodate the higher temps on those cylinders. There have been threads about using braided S/S lines. I can't think of any reason you couldn't repair the hard line with rubber hose of the correct size/temp/pressure rating, flaring the hard line and using good clamps.
Old Feb 5, 2008 | 10:12 AM
gecole80z's Avatar
Thanks Fred
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
Jazsun
Dec 29, 2014 12:14 PM
squarehead
Nov 21, 2014 08:02 PM
