Stealthram VS Carb Single Plane EFI intake
Old Jan 11, 2010 | 12:13 PM
B'klyn9C1's Avatar
I looking to build a 383 ci LT1 for my 1995 Caprice 9C1 but as you know I am not a fan of the Stock LTx intake manifold. My goal is to get 420 RWHP and over 400 RWTQ. Not sure on what heads to use a pair of Advanced Induction alum stockers or a set of AFR's 195 CC Eliminators or TFS 21* heads.
I was real sweet on the Holley Stealthram and I have the room for it under the hood. But I learned that it has the same poor air distribution issues as the stock LT1/LT4 intake has. In that especially at part throttle the rear (4) cylinders get straved for air than the front cylinders that are closer to the throttle body.
Than I got on the Carb Style Single Plane EFI intake bandwagon with a progressive 4 barrel throttle body. Here most guys say don't bother with this setup inless you intend to build a max effort motor in a car that is trailered to the track not in daily driver which my car is.
Please tell in your opinion what do you think is the best for my application???
Old Jan 11, 2010 | 03:25 PM
Bersaglieri's Avatar
Those numbers are easily achieved with well ported stock heads, stock intake, the right custom camshaft, all working together with complimenting parts. AI or Lloyd Elliott can get you there, I suggest talking to both and go with who you want.
In my opinion you'd be throwing your money away going with anything other than the stock style intake. Although porting it may help you reach your goal.
-Dustin-
Old Jan 11, 2010 | 04:47 PM
RamAir95TA's Avatar
-Dustin-
Bingo. I said the same thing over at tech.
Queens94z28
Dec 20, 2014 09:11 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Elcojoe
Nov 17, 2014 10:27 PM
newby
Jul 25, 2002 03:22 PM
