Startup issue
Old Aug 9, 2011 | 06:07 PM
94 Polo Z Convertible's Avatar
Startup issue
This is the newest addition of startup problems. Battery is low, using a charger/jumper, get a god awful electrical buzzing sound above the brake pedal every time I turn it over. Is it likely to be the ignition switch on the column?
Old Aug 10, 2011 | 05:19 AM
Guest47904's Avatar
Guest
Re: Startup issue
No what you hear is a relay trying to pull in. Ideally you don't want the battery voltage to drop below 11 volts while cranking.
mdenz3
May 22, 2015 09:25 AM
sseeya
Apr 9, 2015 06:38 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Lions3
Apr 11, 2003 10:55 AM
