Starts Sluggish - Old starter?
Old Jun 4, 2004 | 11:36 AM
Z28WannaB's Avatar
I used to drive a 2002 Honda Civic EX 5spd. When you'd turn the key it would instantly kick on the engine.
In the Formula it makes the "gung gung" noise a couple times before it kicks on the engine. Could the starter be biting the dust? Or does it just take more energy to turn over a V8?
- Formula V8
Old Jun 4, 2004 | 03:20 PM
MEAN LT1's Avatar
Re: Starts Sluggish - Old starter?
- Formula V8
If the battery and altonator(sp) is good then i would replace the starter
Old Jun 4, 2004 | 04:06 PM
As noted above, first check the alternator condition? Then the state of the battery charge. If that checks out, check the condition of the starter. A healthy system should kick in and start with the first touch of the key. A starter that is drawing too many amps can screw up the power availble for the injectors and ignition, making the startup painfully slow.
Old Jun 4, 2004 | 09:39 PM
1 Nasty Bird's Avatar
My starter was a lil slow and the nose broke off, after i got the new one in it seems it cranks twice as fast.
eazyZ
Mar 1, 2015 07:12 AM
warmeck
Feb 5, 2015 11:04 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
97z28k&N
Jan 9, 2015 04:58 AM
A's 91 Z28
Dec 7, 2014 12:09 PM
