Starts, runs great, dies, won't start, repeat
Old Jun 8, 2009 | 02:36 AM
Hood_Lum's Avatar
Unhappy Starts, runs great, dies, won't start, repeat
The car mysteriously died on me one night after driving a few miles and would not restart. Had it towed home and tested a spark plug wire for spark. Got no spark. Next day, disconnected the Crane Hi-6 and it started right up. Drove it for a couple of miles and it died and would not start up again. Came home at night and just for kicks tried to start the car. Started right up.
It seems to die out on me after it warms up. Bad ICM?
Old Jun 8, 2009 | 12:55 PM
Hal Fisher's Avatar
coil, icm, opti seem to be the most common culprits.
Hal
Old Jun 8, 2009 | 12:59 PM
greasemunkey's Avatar
sounds alot like what my car was doing
i tried just replacing the icm
no change
so then i nutted up and bought a new opti and coil
havent had a problem since
nock on wood
how many miles do you have on the car?
have you replaced your opti and coil before?
Old Jun 8, 2009 | 01:05 PM
Hood_Lum's Avatar
never replaced the coil or icm before.
125k miles on the car. Changed the opti twice.
Old Jun 10, 2009 | 01:33 PM
Hood_Lum's Avatar
I think it's the opti again. Not getting a signal on the white wire going to the ICM.
Old Jun 11, 2009 | 09:15 AM
Hood_Lum's Avatar
I have a reprogrammed obd1 pcm so it's not throwing any codes.
Could it be just a bad wire from the opti to the pcm?
I bought a ICM from Kragen and swapped it after the car died and it didn't help.
Of course, I just disconnected the connector and connected the new ICM just hanging there. Did the back of the ICM have to be grounded?
Old Jun 11, 2009 | 09:24 AM
lt1srule's Avatar
opti
Old Jun 12, 2009 | 05:34 AM
Guest47904's Avatar
Guest
Why are you swapping parts without doing measurements
Or at the very least get out the hair dryer and warm some things up.
Old Jun 12, 2009 | 05:50 AM
Hood_Lum's Avatar
Car would run for 10 mins and die. After it died I swapped the ICM to see if a known good ICM would start it back up. Since it didnt work I returned it.
I had a extra PCM laying around so I swapped that too. No change.
I measured the white wire and got no voltage.
On the distributer harness I got the correct values on A, B, C and D was to ground.
Which leads me to believe it's a bad opti. I also got codes 16 and 41 EST open.
Old Jun 12, 2009 | 11:46 AM
johnnyb's Avatar
I have code 16 and 41 and im in the same boat with you as far as dying after it heats. Im changing the opti tomorrow so ill llet you know how it goes
Old Jun 13, 2009 | 03:14 AM
Hood_Lum's Avatar
So I swapped the opti and the cars running.
But now it doesnt feel as powerful as before so I plugged in my laptop.
I got the trouble code 49. Something to do with the MAF.
Anyone have any info on this trouble code?
Scottylt1
Jan 8, 2015 02:48 PM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Scottylt1
Dec 4, 2014 12:31 PM
nophix
Nov 30, 2014 10:26 PM
