Starting up stored car...
Old Mar 22, 2004 | 11:54 AM
94foormula's Avatar
What is your guys procedure for starting up a car thats been stored all winter?
I havent done much to the stock ride so its just going to get an oil change, it wouldnt hurt to pour a quart under each valve cover before its started up would it?
Anything else you guys do?
Old Mar 22, 2004 | 11:58 AM
KCFormula's Avatar
If you want to prime your engine with oil before it starts you can always disconnect your coil and then let the starter turn the oil pump a bit. But I have stored my car for many years and I just hook up the battery and go.
Old Mar 22, 2004 | 02:37 PM
94foormula's Avatar
Just start it up huh? Hmm maybe ill unplug the coil just in case.
Anyone else do anything different?
Old Mar 22, 2004 | 03:00 PM
ibanez6rg's Avatar
Uhh may want to take out the relays or whatever for the injectors, also, if you're gonna prime it.
Old Mar 22, 2004 | 03:11 PM
jbird's Avatar
it seems like I read somewhere on here to unplug the relay for the pcm and it would kill fuel and spark, then crank it and prime it
Old Mar 22, 2004 | 04:34 PM
94foormula's Avatar
Ill just unclip each one, only takes a second.
Old Mar 23, 2004 | 07:13 PM
My95Z's Avatar
i usaully just start it... I heard someone on hear said you could take out your spark plugs..?
Old Mar 23, 2004 | 07:19 PM
"White Knight"'s Avatar
I just start her.
Old Mar 23, 2004 | 07:27 PM
z71camaro's Avatar
Change the oil, pull the PCM fuse, turn it over for about 10 or 15 secs, then fire the bitch up and don't worry about it.
Old Mar 23, 2004 | 07:40 PM
warwickbass's Avatar
Originally posted by "White Knight"
I just start her.
****ing brilliant.
armedtrigger
Feb 24, 2015 08:30 PM
grgguy
17
Feb 23, 2015 07:57 PM
ChrisFrez
Feb 15, 2015 08:12 AM
Amshnock
14
Jan 18, 2015 11:47 AM
Dec 1, 2014 08:08 AM
