Idle in park...acting up a little bit...
Old Mar 23, 2004 | 07:02 PM
AxeGrinder30thZ's Avatar
What should the normal idle be at? When my car is in park, it changes. It will be around 850-900 and about 5 seconds later, will jump back up to around 1000-1100. A few moments later, it will go back down and then up again. Any reason why it's doing this?
Old Mar 23, 2004 | 07:34 PM
warwickbass's Avatar
Your Mass Air Flow sensor might be bad. Mine does that occassionally.
Old Mar 23, 2004 | 07:36 PM
jbird's Avatar
At first I was gonna say your a/c compressor might be coming on and off, but 1100 or so seems way too high for that, I agree w/the above
Old Mar 23, 2004 | 07:41 PM
"White Knight"'s Avatar
Yea i agree with the above too.
I think you can just unplug it and start her up and see if it still does it......should run on the pre-set parameters and see if it clears it up. Plug her back in and see if it does it again.....if it does, it's probably bad.
Make sure your foot's off the throttle lol
68camaroboltz
Oct 5, 2015 01:46 PM
Double aught
Oct 2, 2015 11:29 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
autoxr166
Sep 25, 2015 04:21 PM
