starting problem
Old Feb 27, 2010 | 05:04 AM
EatMD69's Avatar
starting problem
i have recently bought my camaro when i go to start it i have to wait for the battery to "charge" up you could say then the car usualy starts right up. i think it might be a mix of the starter and the battery but im not that sure.
Old Feb 27, 2010 | 05:12 AM
AFK9's Avatar
What kind of car do you have?
Describe why you think it is "Charging up"? What is it doing. Sounds, lights flickering etc..
Old Feb 27, 2010 | 05:21 AM
EatMD69's Avatar
94 z28 all the lights come on and work and once the car starts it funs fine just getin it to start is the issue no noises nothin flickering
Old Feb 27, 2010 | 05:36 AM
edz97's Avatar
Does the starter turn the engine over? If the engine turns over and not starting right away, it sounds like your fuel pump needs to prime. If the check valve at the fuel pump is bad (or a leak, stuck injector, etc) it will cause a loss of fuel rail pressure when sitting for a period of time.
Old Feb 27, 2010 | 12:38 PM
Slick-Z's Avatar
Hey man there is nothing charging the battery until the car has started then the belt driven alternator charges the battery up constantly. If its trying to crank over then the battery are doing there job and it still has nothing to do with the alternator. There are a list of things that could be wrong like fuel not reaching injectors due to leak, clogged filter, bad pump, also intake manifold vacuum leaks, dirty air filter, loose connections on the engine ground, or somewhere in the ignition system. Also if the engine tries to turn over but you notice that when as its trying it actually turns the engine in a slow manner that could be your battery being discharged. One time i had my battery go out, one of the cells went out. So there was power getting to the starter but not enough to rotate the engine. Let me know man if you can tell that when the engine rotates strong when your trying to start it every time then its definately not the battery of starter.
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
97SSdude
Dec 31, 2014 07:43 PM
