starting problem
Old Mar 29, 2008 | 02:42 PM
z28racerf38's Avatar
starting problem
i have a 94 z28 and it takes a good 30secs of cranking to get it started every time when it was never like this before, im thinking the opti is going bad anyone have any ideas?
Old Mar 29, 2008 | 03:35 PM
2000GTP's Avatar
A number of things can lead to a hard start, especially ignition components. If the fuel system is not operating properly either, that can also lead to an issue. How does the car run otherwise, once you do get it to fire? Do you have access to a fuel pressure gauge, if so, see what the fuel pressure is doing during all of this.
Old Mar 29, 2008 | 06:25 PM
OBE1 95Z28's Avatar
Another vote to check the fuel pressure. Common issue for the check valve in the fuel pump to get stuck open, allowing the fuel priming pressure to bleed off.
Old Mar 30, 2008 | 12:37 AM
yea thats what quite a few ppl have said it seems like fuel.
Old Mar 30, 2008 | 01:02 AM
Kaj's Avatar
Kaj
if it's not fuel related, which it probably is. Get your alternator tested along with your battery.
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
97SSdude
Dec 31, 2014 07:43 PM
