Starting problem
Old Oct 24, 2006 | 01:51 PM
californiaz28dude's Avatar
Starting problem
Does anyone have any idea what this problem is.. I had my 95 z28 sitting for about four weeks. I went to start it up and the battrey was dead. ok i figured. I jump it. I tried and then it just made this clicking noise. Really fast. So then i thought it was just a bad battrey so i tried charging it. And now the battrey is charged but it still wont start. Just makes a fast clicking noise.. any ideas?
Old Oct 24, 2006 | 02:12 PM
BUBBA's Avatar
Battery and/or connections. JMHO
Old Oct 24, 2006 | 07:28 PM
95z28man's Avatar
Sounds like a fuel pump issue to me. Do your lights and everything work? I had the same issue when my fuel pump went bad. Just a rapid clicking noise and no fuel coming through. Especially since it's been sitting for weeks on end.
Old Oct 24, 2006 | 08:55 PM
respectirocz's Avatar
you charged the dead battery? did you test the battery to see if its holding a charge? i think it may still be a battery problem
Old Oct 24, 2006 | 09:20 PM
z28trick's Avatar
take your battery to advance and have it tested
Old Oct 24, 2006 | 09:56 PM
oneslowz28's Avatar
Have the batt tested and also check the connections on the starter . Tap the starter syllonoide<sp> with a hammer it may be stuck. If the batt is good doubble check all the large gauge wire connections grounds and positives. the ground on the passenger well is prone to croosion under the fender well. loosen it and check it for corrosion too.
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
97SSdude
Dec 31, 2014 07:43 PM
