starting problem
Old Nov 5, 2004 | 10:13 PM
blackcamaroz28's Avatar
starting problem
has anyone ever had there car crank over fire up for a second then the power dies out on the car and it stalls? i have been experiancing this problem right after i put a opti and waterpump in the car. could it be the starter or could i be misfiring or something. i am almost positive aall the plug wires are correct. or maybe my engine is severly flooded and i have to look into getting new plugs.
Old Nov 5, 2004 | 10:18 PM
indieaz's Avatar
Re: starting problem
if the car is starting up for even a split second and stalling then it has nothing to do witht eh started. As soon as the car fires the started is out of the equation. I would guess the opti was not put on right - what year is the car?
Old Nov 5, 2004 | 10:45 PM
its a 96 with the vented opti. is there anything to kno besides making sure the pin is in the slot, it can only go in one way right?
Old Nov 5, 2004 | 10:48 PM
i broke the opti fixing the first problem which was the waterpump. i put the new waterpump on and all of a sudden the car had no spark anymore because i broke the optical eye sensor, so i had to get a new opti. i turned the car over quite a bit with no spark. i am thinking its really flooded or fouled out.
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
97SSdude
Dec 31, 2014 07:43 PM
