starting issues
Old Dec 15, 2008 | 05:21 PM
blubird's Avatar
starting issues
i have a 93 z28, ive replaced my starter now a few times, and this new one wont turn over at all, ive also replaced the ignition switch but still no help, ive been able to jump the starter and got it to start like that and ive had the starter bench tested and said to be good, what could it be ?
Old Dec 15, 2008 | 07:54 PM
RamAir95TA's Avatar
Have you double and triple-checked that you reconnected the starter wiring (solenoid and motor) correctly?
Old Dec 16, 2008 | 04:27 PM
blubird's Avatar
yes everything is connected correctly, but when i turn the key i can hear the solenoid click once but it wont turn the starter over at all
Old Dec 16, 2008 | 05:43 PM
blubird's Avatar
i noticed there is a little rectangular black box underneath the passenger side carpet and it has a plug coming out the right side labeled "OKI" and its not plugged into anything, does anyone know what this is or where it plugs into ?
Old Dec 16, 2008 | 10:42 PM
94Firehawk161's Avatar
With the starter still hooked up, take a DVOM and hook it up to the small terminal on the starter. Try cranking it over and see what the voltage is. If the solenoid is operating, but the starter motor itself is not turning over, the voltage should be near battery voltage (11.5v-13v depending on the state of charge of your battery). If the voltage drops significantly, then check the trigger wire coming from the ignition switch. Check it the same way, plugged in, then unplugged. If the voltage drops significantly (below 11v) with it plugged in, and does not drop significantly when unplugged, it is most likely the switch causing the problem. You will need to consult a wiring diagram to be sure you are checking the correct wire on the ignition switch. DO NOT USE A TEST LIGHT, IT WILL ONLY TELL YOU IF THERE IS VOLTAGE and will not tell you how much voltage is there and if there is any voltage drop.
Old Dec 22, 2008 | 02:56 PM
blubird's Avatar
by small terminal on the starter do you mean where the negative wire connectd to it ?
Scottyboy
Feb 11, 2015 10:28 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Alex Barnes
Jan 24, 2015 10:21 PM
David Dorris
Jan 17, 2015 08:10 PM
