starting issue after rebuild
Old Dec 11, 2010 | 04:15 AM
gearhead90's Avatar
i just rebuilt my LT1...put a 503/510 cam, 1.6 full rollers, .600" springs, MSD cap and rotor set, long tube headers with y-pipe and all machine work to heads and block...now i went to start it up with a full battery and brand new gas added to some 4 month old gas and it keeps turning over but wont start and seems like its not turning over fast enough to fire correctly....i got it started twice but cant seem to get it started again... iv gone over everything wire wise..does it sound like a bad ground? im goin to just go ahead a put a high torque starter on and see what that does...anyone have any suggestions? i would appreciate any ideas that i could try to get it started
Old Dec 11, 2010 | 03:36 PM
sickler's Avatar
Re: starting issue after rebuild
did you get the pcm tuned?bigger injectors or fuel pump?timing off?
Old Dec 12, 2010 | 04:14 PM
97Z28Muscle's Avatar
Dosen't sound like a bad ground. If that was the case, it probably wouldn't crank at all. Usually it's a firing order problem, or maybe just a battery that has lost it's charge.
Old Dec 12, 2010 | 04:38 PM
Bails098's Avatar
maybe valve lash is too tight. check out the link for adjusting lash.
http://shbox.com/1/4th_gen_tech2.html#adjust_valves
Sergio
Jan 27, 2016 04:27 PM
Alex Barnes
Jan 24, 2015 10:21 PM
importkiller94
Jan 17, 2015 09:03 PM
David Dorris
Jan 17, 2015 08:10 PM
