starting issue
Old Oct 24, 2011 | 09:35 PM
bigwalk's Avatar
starting issue
I was given a 96 z-28, since receiving the car I have installed an lt1/6-speed combo. It will run for about a minute then quite, when running I can pat the gas and nothing happens. I pulled the plug's, and they were drinched with gas. Put in new plug's, with the same result's. The exhaust is not hooked up yet. Any advice would be greatly appreciated.
Old Oct 24, 2011 | 09:39 PM
raulz28's Avatar
From: 5 minutes from the warzone in mexico(south texas)
Re: starting issue
Any codes?
Old Oct 24, 2011 | 09:47 PM
bigwalk's Avatar
Re: starting issue
don't have a scanner yet
Old Oct 24, 2011 | 10:03 PM
raulz28's Avatar
Re: starting issue
Well it sounds like you don't have spark so it could be a couple of things from the opti,, coil, etc.
Old Oct 24, 2011 | 10:10 PM
bigwalk's Avatar
Re: starting issue
it start's but doesn't run long
Old Oct 25, 2011 | 12:47 AM
cptr0n's Avatar
Re: starting issue
My brother just went through the same problem. He wound up putting in a vats bypass and everything runs good now.
Old Oct 25, 2011 | 05:16 AM
bw_hunter's Avatar
Re: starting issue
It won't start if it's a VATS problem.
Get a scanner and get any codes
Without the exhaust joked up you are confusing the oxygen sensors. Fix that first.
Check the fuel pressure.
Check for internal fuel leaks....leaky injector dumping fuel.
Old Oct 25, 2011 | 09:38 AM
Psycho's Avatar
Re: starting issue
With an open exhaust the O2 sensors see alot more air so they tell the computer to add more gas to compensate. Close up the exhaust and that part of the equation can be eliminated.
Old Oct 26, 2011 | 12:23 PM
PWR SHFT's Avatar
Re: starting issue
Or disconnect the o2's and let it run in open loop.
Old Oct 26, 2011 | 10:26 PM
bigwalk's Avatar
Re: starting issue
do you think the opti may be bad
Scottyboy
Feb 11, 2015 10:28 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Alex Barnes
Jan 24, 2015 10:21 PM
David Dorris
Jan 17, 2015 08:10 PM
