Starting Issue
Starting Issue
I have a 96 Z28. When the car gets hot it will not restart. Acts like the battery is dead and starter just cicks or does nothing. I have replaced the starter, alternator, and battery. Cleaned all contact points on starter and on ground cables. Still the same. With the car hot it will not crank even if I use the start booster on the charger. I am thinking the new starter is NFG. Any suggestions.
Autozone starter?
Sounds like maybe a bad solinoid to me. Have you tested the charge on the new alternator/ battery?
Anyone know if an ignition switch would cause this?
You might check out shoebox's website, I think there is a no-start write up.
Starting Issue
John
Alex Barnes
Jan 24, 2015 10:21 PM
