Starting issue
Old Jul 14, 2005 | 12:19 PM
lt4 fd's Avatar
Starting issue
Every so often after the car has been sitting over night Ill come out to start it and it will jump to about 1500rpm like normal but fall back to 0 just as quickly and on occasion burble for a split second ad 200 rpm before dropping to 0. Ill try again and it always starts fine the second time, it also cranks right up the first time so its not like I have to REALLY crank on it or anything. Any tips?
Old Jul 14, 2005 | 12:31 PM
96ws-6's Avatar
Re: Starting issue
mine does the same thing so i am curious about what this is also....
Old Jul 14, 2005 | 01:21 PM
Black_95Formula's Avatar
Re: Starting issue
Hmmmm... From what I read it might have something to do with the fuel pump. Maybe it's not priming right. This is a long-shot but it's the 1st thing that came to mind.
Is the pump stock? Do either of you have any problems when the car is running, like hesitation, loss of power, etc?
Old Jul 14, 2005 | 06:54 PM
lt4 fd's Avatar
Re: Starting issue
Mine is a stock pump with 90k miles on it and yes my car is down on power lately quite a bit at all rpms... It also sounds different but I contributed all that to a cat possibly blowing apart and lodging itself wrong in the exhaust system which happened once before... I thought fuel pump as well but wasnt sure if it would give me those symptoms..
Old Jul 15, 2005 | 09:18 AM
Re: Starting issue
How about your opti? Is that stock too? Also, have you checked all your plug wires for burn marks, and all your plug boots to see if any have melted? I would start there first, make sure there is no arcing -- pop your hood at night and look for sparks.
Old Jul 15, 2005 | 01:12 PM
lt4 fd's Avatar
Re: Starting issue
I'm about to replace my plugs and wires and my opti has maybe a couple thousand on it since it was replaced. I am fixing the coil, plugs, wires and exhaust system here soon so if its none of those you think it could be the fuel pump? I will check for arcing regardless, thanks.
Old Jul 15, 2005 | 01:14 PM
TobyZ28's Avatar
Re: Starting issue
Slap on a fuel pressure regulator to see whats up, then take it from there
Old Jul 15, 2005 | 06:33 PM
lt4 fd's Avatar
Re: Starting issue
you mean a fuel pressure gauge? I was going to do that as well
Old Jul 19, 2005 | 11:50 AM
TobyZ28's Avatar
Re: Starting issue
erm yea a guage heh
Old Jul 19, 2005 | 07:20 PM
lt4 fd's Avatar
Re: Starting issue
Fuel pressure is about 35 or so at idle and just above that at cruise and when I get on it it goes up around 43 or so, sound normal? I'm thinkin Im gonna pull the exhaust off again and see if it helps any....
Old Jul 20, 2005 | 08:34 AM
Re: Starting issue
Did you check it at idle with the vacuum tube off the regulator?
Old Jul 20, 2005 | 02:11 PM
lt4 fd's Avatar
Re: Starting issue
... no I just hooked it up and drove around watching it, what would taking the vacuum hose off tell me?
Old Jul 21, 2005 | 08:14 AM
Re: Starting issue
It would simulate fuel pressure at WOT while your car is at idle. It should be 43.5 PSI without the vacuum tube at idle. That way you don't have to drive around with it and increase the chance of a fire
Scottyboy
Feb 11, 2015 10:28 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Alex Barnes
Jan 24, 2015 10:21 PM
David Dorris
Jan 17, 2015 08:10 PM
