Starting the car without a water pump
Old Jul 3, 2007 | 09:33 AM
ZL1modified's Avatar
So i have two optispark distributers that are bad and i am going to make them into one "hopefuly" working one...
one has a good sensor and the other has a good cap and rotor...
i want to know if it would hurt the car to start it without the water pump... long enough to see if the car will start. because right now the car will not even start...
Old Jul 3, 2007 | 09:39 AM
hotrod18_69's Avatar
I've done it, you'll be fine..
Old Jul 3, 2007 | 09:48 AM
Javier97Z28's Avatar
Moderator
You can run the car for a few seconds like that, no biggie.
Old Jul 3, 2007 | 10:19 AM
wrd1972's Avatar
Yup, I do it too. A cold engine should be good up to 30 seconds easily and safely. This is great advice for anyone installing the opti.
Old Jul 5, 2007 | 11:10 AM
user 647483's Avatar
That's how we tested mine to figure out if we needed to pull the cap and rotor back off and do the opti body as well.
Old Jul 5, 2007 | 12:03 PM
Z28LT1_Just_Nasty's Avatar
When I installed my past few opti's I always start it just to see if it fires up then shut it off after a few seconds. Don't want to throw it all back together just to find out it doesn't work. I never had an issue doing this. When I did it though, it didn't want to rev, I believe it was because the coolant temp sensor wasn't connected, just something to keep in mind.
Old Jul 5, 2007 | 09:53 PM
OBE1 95Z28's Avatar
You could always plug the sensor wiring harness into the unmounted water pump sensor to get around this issue.
Old Jul 5, 2007 | 10:34 PM
BrokeMofugga's Avatar
Thats whats i did.
Old Jul 6, 2007 | 07:36 AM
scottso's Avatar
Me too.
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
thenewkid
Nov 27, 2014 09:41 AM
cristian1311
Nov 23, 2014 02:22 PM
teedoff59
Aug 8, 2002 01:36 AM
