Starting a 383 build
Old Aug 27, 2008 | 09:11 AM
black/blue's Avatar
Working on deciding what to do with this build. I only drive the car when messing around and when I can make it to the track.
I plan on getting all the machine work done right and fron what Ive read it will add up so im looing for suggestions on budget parts for the rotating assembly ect.
150-200 shot on it and AI or LE head package since I have a new set of heads on the motor that is currently in my car now.
Old Aug 27, 2008 | 09:53 AM
slomarao's Avatar
Mahle power pack pistons. Eagle forged SIR rods, scat 9000 cast crank.
Beware of budget n2o builds. Scat and Eagle are going to be cheaper than most other guys. And a 400rwhp car with a 150-200 shot is when you may want to go completely forged so think about how greddy everyone gets with n2o??
I would also address the mains, use n2o piston rings, etc. Build the motor right the first time instead of the 2nd.
Old Aug 27, 2008 | 09:58 AM
SS MPSTR's Avatar
Mahle recommends no bigger than a 150 shot on their power pack piston sets.
I'd elect to go Scat as a minimum and maybe for a few dollars more, step up to the Compstar stuff. A well built short block with a set of AI 200cc heads and a sane HR cam from them, as well as well-thought out supporting parts, will give you a rush everytime you drive it and many miles of good service. Ron and Phil have done this a few times - give them a call.
Old Aug 27, 2008 | 10:13 AM
black/blue's Avatar
I intended on going forged just wasnt sure where to start from there. Everyone I know here runs dirt cars or big blocks. So mahle would be a no go I guess, The callises assembly I found have mahle pistons for 2100 then the dragon slayer and lunati kits are 24-2500.
Old Aug 27, 2008 | 10:28 AM
rock1501's Avatar
compstar
Old Aug 27, 2008 | 10:38 AM
black/blue's Avatar
Checked AI site and even their kits come with mahle pistons.
Old Aug 27, 2008 | 11:40 AM
slomarao's Avatar
Call Llyod Elliot and ask him. He will also be able to save you a couple bucks on a shortblock.
Compstar is a better choice.
Old Aug 27, 2008 | 08:51 PM
black/blue's Avatar
Which off the shelf piston would be good for up to a 200 shot, Im not finding any real definite answers.
Old Aug 27, 2008 | 10:52 PM
whyrun's Avatar
Good luck, I asked the same Question about a week ago.. It was a dead thread when it set sail. Looks like I'm going with the Mahle pistons And I'm going to spray a 200 on them And I've heard of other people doing the same even though they don't recommend it but heck you can spray a 100 shot on the stockers so why couldn't you spray 200 on a forged unit?
Old Aug 27, 2008 | 11:23 PM
black/blue's Avatar
Only for sure set Ive found so is if I go with a 355 I can run the ross 90465.
Old Aug 28, 2008 | 12:37 AM
bombebomb's Avatar
Id look into a ross or JE piston. I personally went for a nitrous built piston, of course thats overkill for you im sure.
Old Aug 28, 2008 | 01:44 AM
MachinistOne's Avatar
Build it strong now, because once you get on the power it's easy to get "bored" and push for more at which time you will need the stronger parts.
For a budget build I would highly recommend the Compstar, or a K1 crank, Compstar, Manley, or Scat H-beam rods (6.0"). For pistons a JE nitrous piston would be the best choice - if you are starting with a 200 shot, it's only a matter of time before you are going higher. Wiseco also makes some nice nitrous pistons.
I have not used that much nitrous on stock LT1 heads, are you guys having any deck rigidity issues at those cylinder pressure levels?
Old Aug 28, 2008 | 08:53 AM
rskrause's Avatar
Moderator
As usual.I agree with M1. The top ring land on the Mahle piston is too thin for a "nitrous" piston.
Rich
Old Aug 28, 2008 | 11:10 AM
bombebomb's Avatar
+1 on the overbuild for future use, its ALOT easier and cheaper doing it now then it will be in the long run. Also just a note to the guy max nitrous on a stock head is normally around or below 200~.
Old Aug 28, 2008 | 11:53 AM
slomarao's Avatar
use some arp head bolts, JE or another very good piston,(Ross, Diamond) and have the rings gapped for n2o.
You may even want to build a n2o motor, a 200 shot is boarder line, going fully forged and expensive may be your ticket to doing this once. I would really think about your n2o use. It will dictate how much bottom end you will need.
