Starter wiring help
Old May 24, 2006 | 04:21 PM
modracr62's Avatar
Starter wiring help
Is there any reason i would have power on the purple wire that goes to the starter at all times when the key is on? When you turn the key to start position it has no change in voltage. Thanks for any help..
Tim
Old May 24, 2006 | 07:22 PM
Re: Starter wiring help
Have you checked it with the purple wire removed from the solenoid?
A bad ignition switch might cause it.
Old May 24, 2006 | 08:40 PM
modracr62's Avatar
Actually i checked it from the plug in the kick panel. I stripped my stock harness out to install A FAST XFI setup and cant figure out why it is powered all the time when the key is on. When i turn the key to the start positiion i can hear a clicking under the dash?
Old May 25, 2006 | 04:18 PM
modracr62's Avatar
anyone?
Critter
Jul 7, 2015 08:33 PM
robcarnut
Mar 20, 2015 03:40 PM
eazyZ
Mar 1, 2015 07:12 AM
ModdedNerd
Feb 5, 2015 04:37 AM
Jeff1904
Jan 3, 2015 12:00 AM
