Starter run-on !!!
Old Jul 28, 2005 | 04:47 PM
WS Sick's Avatar
Starter run-on !!!
What would cause a starter to continue to go after the key is released? We couldnt get it to stop until the battery was disconnected.
The only sign of trouble is the starter wire (small terminal) was laying against the header, so it was possibly burnt.
Old Jul 28, 2005 | 04:55 PM
chr10spoke's Avatar
Re: Starter run-on !!!
mine did that about 3 years ago after sitting about a month..I just disconnected the battery. It was weird that never happened in any car I had before. It has never done it since.......
Old Jul 28, 2005 | 05:20 PM
LT4383's Avatar
Low voltage=high amperage; can "weld" solenoid together internally.
Several things can cause the started to run on though, this is just the most common symptom i've seen.
Old Jul 28, 2005 | 05:53 PM
ChickenScreamer94's Avatar
you got lucky. my starter set on fire. talk about crappin the pants. fortunately my car didnt burn to the ground.
Old Jul 28, 2005 | 06:22 PM
btchincamaro's Avatar
Usually a bad solenoid. Sounds like new starter time. Add a remote solenoid kit (ford style) while your at it.
Old Jul 29, 2005 | 02:14 AM
Red on Red WS6's Avatar
That happened in my truck at a gas station, glad it did not catch fire Before I could get the battery disconnected the starter locked up.
Old Aug 1, 2005 | 04:20 PM
WS Sick's Avatar
Yep the solonoid was welded together internally, thanks guys for the advice.
Formula Steve
Sep 19, 2023 08:31 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
4586
Aug 18, 2015 07:08 AM
realistyc
Jul 28, 2015 07:32 PM
