Starter Removal
Old Feb 19, 2004 | 02:43 PM
thefox1's Avatar
Starter Removal
Has anyone tried doing this to a 94 TA? I got the bolts off and the wires undone but can't find a place to squeeze it out. The haynes manual says you can do it on the 93-97 without removing the foward exhaust pipe. (I would of already of unbolted the exhaust pipe but I don't have the right size in my ratchet set )
Old Feb 19, 2004 | 02:44 PM
Kataklysm's Avatar
Try just pushing the exhaust over to the side...it should move a little.
Old Feb 19, 2004 | 04:15 PM
thefox1's Avatar
I'll give that a try tomorow, maybe pry it a bit with something. I had to give up today cuz I was freezing my *** off!!
Old Feb 19, 2004 | 10:03 PM
$hawn's Avatar
Take out the bolt on the oil pan that holds a clip holding the tranny cooler lines, then you can move them to the side, but you'll still have to get it in the right position to slid it out.
Old Feb 19, 2004 | 10:07 PM
Don't Look Back's Avatar
Alternately, you can take the bolts off the lower bellhousing shield on the transmission (A4) and slide it out that way.
Old Feb 20, 2004 | 01:49 PM
thefox1's Avatar
I removed the bellhousing and it worked fine. Tnx for the info.
DSMKilla
Jun 11, 2015 05:02 PM
Jun 6, 2015 08:27 AM
lt1matt
Mar 21, 2015 07:35 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
thenewkid
Nov 18, 2014 12:57 PM
