Starter Relay Location
Old Sep 20, 2004 | 10:02 AM
ShawnMacAnanny's Avatar
Hey, i was wondering where my starter relay is. I want to put in a push button start. I did it in my last car, i ran a hot wire to a push button then to i forget which pin, and it worked fine. You just turn the key on and push the button. I want to put it in my cigarette lighter.
Has anyone done this, and is it even possible? I didnt see a starter relay in the panel under the hood so im assuming it must be separately located.
Old Sep 20, 2004 | 12:29 PM
Re: Starter Relay Location
Here is a schematic if you want to try to wire something up. There isn't a "starter relay" per se, but there are some other theft deterrent devices. It is your choice on where you might want to wire in the button switch.
robcarnut
Mar 20, 2015 03:40 PM
Chet1185
Parts Wanted
Mar 15, 2015 04:29 PM
Jeff1904
Jan 3, 2015 12:00 AM
tbyrne
Aug 16, 2002 01:12 PM
bsmith
Jul 19, 2002 06:08 PM
