Starter problem - solenoid?
Old Sep 15, 2005 | 09:56 PM
poolkitman's Avatar
Starter just clicks when I turn key.
The starter pinion is extending to the driveplate but not turning.
The starter motor however does operate when 12v is applied to it.
It is the solenoid?
If so, can I swap it or do I need a whole new starter?
Old Sep 15, 2005 | 10:02 PM
NVetro's Avatar
Re: Starter problem - solenoid?
I have this issue, turn the key back off then back on then back off then back on, FULLY on, not just acc....that what i have to do with mine sometimes...
Old Sep 15, 2005 | 10:16 PM
poolkitman's Avatar
Yah that trick got me through last week but I got cruise nights to go to this weekend... my luck I'll have to pry the driveplate to a perfect spot or try the hammer trick - embarassing eh?
Old Sep 15, 2005 | 10:39 PM
NVetro's Avatar
time for an LT4 starter my friend woo hoo Read up on it.....
Old Sep 15, 2005 | 11:17 PM
poolkitman's Avatar
OK thanks
Old Sep 16, 2005 | 12:40 AM
blunto's Avatar
It is the solenoid?
What variable are you inducing on your starter that allows it to receive 12V? Under what circumstances is it NOT getting 12V? If it currently is NOT getting proper voltage, then that is a problem for ANY starter, 100k mi. stocker and brand new LT4 alike. Don't go buy anything just yet.
Old Sep 16, 2005 | 05:57 AM
SnakeOiler's Avatar
I think you answered your own question
Old Sep 16, 2005 | 03:55 PM
poolkitman's Avatar
Fixed - swapped solenoid. The solenoid operated but it wasn't tranferring voltage over to the starter motor once the pinion extended. Unfortunately that part of the solenoid didn't come apart.
HectorM52
Jul 30, 2017 11:46 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
edman
Mar 13, 2015 09:39 PM
jermaine_rashad
Advanced Tech
Jan 4, 2015 02:32 PM
Jeff1904
Jan 3, 2015 12:00 AM
