Starter problem this morning...can you name this sound???
Old Apr 20, 2003 | 10:03 AM
Robbie's Avatar
Back when i had my clutch installed my car wouldnt start sometimes. Like the starter was locked up and it was just "click click clicking" when I turned the key over. After my clutch install i had no problem with it for 5 months. Now I went out to my car and its doing it again. I turn the key over, all the lights on the dash come on, the battery isnt dead, it just goes "click click click click" real fast. Is my starter gone?
Old Apr 20, 2003 | 10:12 AM
burnemonm1's Avatar
I would hook some jumper cables up to it first cause it really sounds like a low bat, then I would check all your terminals.
Old Apr 20, 2003 | 11:27 AM
Robbie's Avatar
Could it be my battery even if my power locks, windows, etc are still working?
Old Apr 20, 2003 | 12:05 PM
IllusionalTA's Avatar
Sounds just like a battery.. Takes more power to start a car then roll up a window.. Charge it up and see how it goes.. My starter is on its way out and it click's andi have to play w/ the key a few times for it to start.. I"m lazy what can i say..
Old Apr 20, 2003 | 12:06 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
yes, PW dont draw a ton of electicrical power where as turing a motor with 10.5:1 compression does
Old Apr 20, 2003 | 12:12 PM
LS1_03's Avatar
Might even be a bad ground. Like someone else said, check your connections.
Old Apr 20, 2003 | 01:21 PM
Robbie's Avatar
I checked the terminals and they were clean. So I checked the Voltage gauge on the dash and it was reading but looked low. So I rollded her backwards out of the driveway and bump started it and let it charge for a while and all is good. Thanks for the replies.
Magenta_Hearts
Mar 5, 2015 07:01 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
97z28k&N
Jan 9, 2015 04:58 AM
jermaine_rashad
Advanced Tech
Jan 4, 2015 02:32 PM
Jeff1904
Jan 3, 2015 12:00 AM
